Trinary Switch for Fan Control
84cutspreme
1,162
155
Has anyone installed a trinary switch on accumulator to control low press cut-out, high pressure cut-out and electric fan on? I am looking into trying this route with my setup and wondering if anyone has any insight.
like this setup: https://www.vintageair.com/instructions_pdf/11086-VUS.pdf
Texas82GP
Just-a-worm
Apr 3, 2015
8,009
18,772
Spring, Texas
We put Vintage Air in my brother's 78 Z28. We upgraded to the trinary switch so the second electric cooling fan would be triggered by it when the pressure on the high side reached a certain threshold regardless of what temperature the radiator is. The dryer on a Vintage Air system is on the high side. I don't think the Vintage Air switch will mount to the Accumulator on our cars, and the Accumulator is on the low side. You would need to mount that switch somewhere on the high side. You could get the fittings from Vintage Air and make a custom hose with a place for that switch. Give them a call. They are nice folks. Very helpful.
84cutspreme
1,162
155
I was asking them and they were unsure. the new compressor I have with serpentine setup has port for factory high pressure switch. maybe i can make it work
Texas82GP
Just-a-worm
Apr 3, 2015
8,009
18,772
Spring, Texas
I had a better experience than that. I wish I could remember what threads that switch uses, but its been for or more years and to be honest, I didn't look that hard at it. Maybe you could use the factory switch for your compressor? Which compressor are you using?
84cutspreme
1,162
155
its the gm performance setup so I believe it is from 92 camaro. i looked on website n threads are 3/8-24 but vintage air rep told me 7/8-24. so we shall see when it gets here
Texas82GP
Just-a-worm
Apr 3, 2015
8,009
18,772
Spring, Texas
7/8" - 24? Sounds huge! Not what I remember but who knows? Let us know how it shapes up.
84cutspreme
1,162
155
well got the switch today and it will not work for my application. debating on getting high pressure cutoff for camaro but the low pressure cutoff on camaro was inline. cycling switch was in accumulator just like ours. think im just gonna tie into cycling switch with relay as I did before
