kustomkyle said:
Just wondering if there is a way to bring up trouble codes in a post-81' G-body with a computer controlled carburetor? The Chilton's manual I have for my car has a section listed for it in the table of contents, but on the page it is supposed to be on, there is nothing but a list of environmental pollutants (????).
Are you asking how to read the trouble codes off the computer, or what they mean? To read them, turn the key on (without starting the engine) and jumper the two upper RH terminals in the ALDL connector under the dash. The Check Engine light will flash. The initial code will always be "12", which shows up as:
ON-(long pause)-ON-(short pause)-ON
This will be repeated three times. Any additional stored codes will then flash in sequence from low to high. Each will also be repeated three times. When all have been shown, Code 12 will flash again and the sequence repeats.
To decode the codes, you need the list for your particular car.
