how exacatly do u remove the trunk hinges somebody drilled right through the threads and all so i cant even mount the trunk onto the hinges i wanna swap them ?
my first thought would be to use a longer bolt that goes through the hinge and use a nut to hold it on. Otherwise you could get a tap and die set and rethread the holes. Then you will just need to get a bigger bolt. It would probably look pretty close to stock that way without replacing the hinges.
yeah i can proably try that too just drill through the other side of the trunk and run a bolt straight through but i really want to know how to take off the hinges
