MALIBU Trunk moisture
Who doesn’t love an epoxy. So many. You got a favorite brand? Dez
I like Evercoat Maxim OEM bead 2k seam sealer. It comes in a 2 chamber caulk tube that fits into common standard caulk guns. But with the resistance from the mixer nozzle its best to use a power standard caulk gun. Some of the other brands of epoxy seam sealers like 3M require special caulk guns. There are some adapter kits you can use to modify standard caulk guns for use with some of the specialized tubes.
Reactions: Dezimade
Great share. Most appreciated!!
the guy in the trunk is the best way to find a leak first remove the interior trunk trim like the carpet and side panels
Reactions: Dezimade
Thanks greatly. As I will be the guy in the trunk
