turn signals no work
rdlkxprs
7
71
Newbie here,
1986 MCSS 4 way flashers work, turn signals do not. Have replaced the switch 2X..
swapped the 4 way flasher with TS flasher - still do not work. any thoughts?
Thanks for reading!
I suppose you also checked the fuse? If I remember correctly, the hazards and turn signals are not on the same circuit.
Thanks for responding - we have checked the fuses. My son is going to have a mechanic at his work check it out.
Update - what are the chances we have gotten 2 bad switches?
Mechanic thinks that could be the issue......
Does this car have LEDs installed? Are the turn signals lighting up solid and not flashing, or are they not lighting up at all? what are the indicators on the dash doing?
If you have LEDs, hazards will work because there is enough load with all the lights to kick the flasher, but not enough with just a turn signal.
Newbie here,
Thanks for reading!
yes, they are LEDs,
My son has the car and I will have to get him to answer the questions .
yes, they are LEDs,
Go buy this, ground the pigtail wire coming out of it, and you'll be good to go.
Newbie here,
Thanks for reading!
update DEC19
Have replaced flasher again and turn signals still do not work. Any other ideas?
update DEC19
Did you replace it with the one I mentioned? And did you ground the wire coming out of it to a verified good ground?
I'll give you the run down here. A flasher is built to recognize when a light is burnt out. It does this by sensing the electrical load passing through it. LED bulbs require much less power, therefore much less load. When you install LEDs, the stock-type flasher senses too little load and lights the signal up solid (or makes it flash faster in newer cars,) to warn you that a bulb is out. Because of this, you need to add resistance to the circuit. There are many ways to do this, but if you have too much resistance then you won't have a warning when a bulb is out. If you don't have enough resistance, you will still have a solid turn signal. Because of this, it's easiest to use an LED compatible flasher, because it takes all the guesswork out.
So, saying that, does your turn signal light up solid? Or nothing at all? If it lights up solid, you have a resistance issue and NEED this flasher, no question. If it doesn't light up at all, then you have a bad connection somewhere. Could be the switch, although very unlikely at this point. You will need to do some hunting with a voltmeter.
Or just give up and put incandescent bulbs back in.
Reactions: Sweet_Johnny
