skryla said:Would 72 350 heads bolt up to the 307 block?
olds307 and 403 said:Here are your issues, tiny port heads that flow 130/105 cfm stock, small roller can with piddly lift, less than 8 to 1 compression, awful factory exhaust and very aggressive timing. If your stuck on stock heads and block, they need much help. You will need custom pistons or a lot milling and max porting. Find a 72 350 with 7a heads and paint it black and build it how you want.
skryla said:olds307 and 403 said:Here are your issues, tiny port heads that flow 130/105 cfm stock, small roller can with piddly lift, less than 8 to 1 compression, awful factory exhaust and very aggressive timing. If your stuck on stock heads and block, they need much help. You will need custom pistons or a lot milling and max porting. Find a 72 350 with 7a heads and paint it black and build it how you want.
Why specifically a 72 engine? I just happen to have on in the shed.
DoubleV said:Well what are your goals with the 307?
