You should change the joint as well. If it's been driven with movement, then it's whipped. Perhaps it would be OK with a 200hp power plant, but aren't you racing this thing?Nope new straps and new yoke.
All that and they DIDN'T recommend a new joint? On top of all that,if nothing else it's cheap insurance.I'm glad it didn't, I took the driveshaft to the driveline shop and they said bad straps or bad yoke so I installed both.
That's what gets me too, a professional shop that has my life in mind would replace that joint. Hell, they'd require it. If it works, it works, but I still worry the caps are smashed/ the needles are trashed. I had a '93 1/2 ton that kept spitting out u joints due to a bad batch from Precision, and an '85 Suburban with a bent shaft- that shaft took out the tail housing and tried coming through the floor and the '93 repeatedly came apart at the rear. Neither is fun, both get expensive quick.All that and they DIDN'T recommend a new joint? On top of all that,if nothing else it's cheap insurance.
