Been a while since I posted on here, am getting married so the whole big $$ cutlass thing isnt going to work out at least not anytime soon.
I have the 383 still its been 2 years now since I built it, still got low mileage. I'm just at the point to where the car can be inspected and be on the road. Which is a huge step, its really going to be gratifying driving my ugly terd around whipping up on everything on the highway. I've been tweaking the holley 770cfm 4160 now for months and finally got it to where it runs perfect. I literally had to replace just about every piece you could replace for tuning. This was the ultimate b*tch of anything ever done...but to everyone who thinks you can't run a XR282HR cam with 2.14 gears and a 3000 stall I've done it, runs like a scalded dog up to 70mph in first gear. I'm afraid to redline it in second being so not street legal. One of the tricks was to curb idle it twice what you'd do for a normal vehicle, and tune the accelerator pump to shove fuel at that high rpm range where the cam is breathing.
The 3000 stall is going to be thrown out for a 1000 rpm stall sometime. Wish I had a manual. The car is going in a different direction. My idea is to make a ton of top end power, at least as much as I can on these internals and with this cam and setup. It's going to now be made for high speed, and decent mileage, maybe 15-17mpg. Just because thats easier and less breaks, and I'll be able to eat corvettes for lunch and maybe a lambo or ferrari from time to time.
The car weighs now 3000lbs. It goes without saying I need suspension.
So the engine has between 440-480 hp after putting everything in all the calculators I could find. The stock internals - 2 bolt main- hypereutectic pistons are supposed to hold 550hp. Heads are patriot performance 195cc intake runners, 76-78cc combustion chambers, 2.08 intake 1.60 exhaust. I'm running sort of low compression for a small amount of boost, estimate 8.5-9.5 comp. When I bumped up the supercharger psi in my 4.3 truck from 9 to 12 the vortech s/c broke. It needs a rebuild. I'm thinking about taking the whole system, gauges, meth kit and all, and shoving it in the cutlass for 3-4psi boost on my current setup. 4.3L and gen 1 sbc have the same front bolt patterns. This would make somewhere in the neighborhood of 550 hp. I would need to run the carb before the centrifugal s/c and run the outlet side of the s/c to the intake manifold. Then manifold reference my powervalve and tune it rich, step cooler plugs, get the right nozzle for the water/meth, and should be ready to go with a few other things.
Question is will it hold? what do you think. What am I overlooking? I dont care about the rear I'm keeping it stock 7.5 until I figure out what to do with the car.
This idea would be nice because my dd truck would be more reliable, and the cutlass would have a lot more power. I think it'll be somewhere between muscle car and supercar territory at higher speeds with 550hp and 3000lbs and that low numerical gear...which is key, I mean theres no other car on the road that can wind out their torque curve this much.
