Can you guys help me understand why it's necessary to compress the springs? i understand that by having the engine in the car and putting jack stands under the lower control arms that will compress each sides spring. since the spring is between the LCA and the frame, The upper control arm can be safely(ish) removed. What I don't understand is what compressing the spring accomplishes? it seems like if the upper control arm isn't only what's keeping the spring in, it could be removed regardless of spring tension.Great recommendations. If the engine is in the car, you'll be miles ahead by just jacking it up and putting it on jack stands under the lower A-arms previously described. Leave the front shocks installed. They can help keep things under the car in case something goes awry.
Be careful with your pickle fork going in after your new ball joint if you go that route to split the ball joint from the spindle. If you tear the boot you'll be taking it off. If it's bolted in, you can replace it easy if you had to, but since it's new and freshly installed, I'm betting just a few love taps may get that thing loose. Don't have to deal with corrosion in there fighting you.
Good luck!
I can tell I'm missing something... I'm about to go start taking things apart and I'm sure it will become more clear to me again. When I did this job the first time the engine was out and I used a spring compressor while replacing ALL control arms, so this is a little different and it's difficult for me to visualize.
Thanks
