URGENT! How to replace wiper blade?? Fighting the spring..
tnovotny
Hi, could please anyone tell me how to replace wiper blade off the arm with nut?? I removed the arm without problem but I m not able to get blade off the arm. Cant figure out how to make spring loose . Thanks for any advise!
Its on 80 regal 3.8 btw.
Re: How to replace wiper blade?? Fighting the spring..
ITS VERY URGENT AS IT RAINS HERE NOW AND I CANT MOVE UNTIL SOMEONE HERE HELPS ME!! I'm in Czech republic now so nobody else can help. Haha. Thanks!
Nobody knows??? It must be very easy!
Re: URGENT! How to replace wiper blade?? Fighting the spring
just the blades or the whole arm? cause the blades should just click on, and to get it off you just push the little plastic piece by where they go on and pull... sometimes they are a b*tch to get off if you dont replace them regularly.... if you are talking about the whole arm, i would imagine its one nut that holds it on, but i could be wrong, im sure a buick guy will chime in
There are no nuts anywhere.
Get a flat blade screwdriver.
If you want to take the blade off try using the screwdriver between the arm and blade to help push it off.
If you need to take the arm off then lift the arm up all the way, and use the screwdriver to push locking tab out. The tab will hold the arm up when pushed out.
Alright. Thanks a lot, guys, after suggestion of using screwdriver it was solved really fast 🙂.
Thanks!
Its amazing how this forum helps fast...)
at the small opening on the blade where the pin goes through it, push that clip down with a small screw driver which will release the blade you you can slide it off while you keep pressure on the clip.
