V6 to SBC Swap
joye227
May 11, 2009
68
6
South Carolina
As you can see I cleaned and painted my frame and I am getting ready to swap in a SBC in my 85 cutlass. I read through this whole forum but I need a straight forward answer about motor mounts. I already have the mounts that bolt to the block, I just need the ones that bolt to the frame. I here people say get the motor mounts out of a mali, monte, or el camino since they are chevy's. But shouldn't motor mounts out of B-bodies(80-93) and F- bodies with V8's work also? I figured they are all the same size.
Oregon350Cutlass
Jan 4, 2008
69
6
Im not sure about the b-body and f-body mounts,I got 87 monte SS mounts for like $5 new from the local auto parts for my 83 cutlass and they worked perfect.
joye227
May 11, 2009
68
6
South Carolina
I ordered the motor frame mounts today. They are the same for all cars with the clamshell style. Autozone has the part number 2292. But I ordered mine from summit and their part number was A2292. Same thing though. I looked it up for an 85 Monte Carlo SS. I also looked it up for my 73 Impala and it was the same part numbers.
Apr 8, 2010
when i did the swap for some reason my fuel pump didnt work anymore. so i puut it a mechanical and it worked fine pulling it through the electric pump. just giving you a heads up.
EastEnder
44
The first post mentions splicing or adding to the wiring harness. What is involved in that? Is that just to give power to the starter, ingition circuit etc? Also, if I go with a carb'd SBC, will any of the old idot lights on my regal work, if i connect new sending units into my sbc and connect them to the old regal harness? (ie water temp, oil press; i cant remember whats on my dash) Thanks for any help.
jrm81bu
3,000
61
48
Antwerp, OH
joemomma918 said:
Can you use the same transmission if swapping the buick v6 to a chevy 350?
Only if it is a dual pattern bellhousing transmission.
79KLASSIK
n00b
Sep 10, 2010
2
i guess i have a similar question to this topic. i have 79 malibu that came with v6 3.3 motor. i changed to v8 4.4 260 out of another 79 malibu and i recently found a SBC 305 v8 but out of a 78 malibu. will it fit in my 79 and should the upgrades i to put the 4.4 v8 work for the 305 v8? also will it work for the time being with the stock 3 speed transmission. im new to this but learning so bear with me please. i swapped the engine my self and it runs great. so i can learn. just need some help, thanks.
Oregon350Cutlass
Jan 4, 2008
69
6
The 305 should drop right in and mate up to your trans no problem.Thats assuming the 4.4 is a small block chevy.I have never heard of a 3.3 or a 4.4.Only 3.8l 231 v6, 4.3v6 and the next step is 5.0 305v8 but I could be wrong.If I am someone will chime in and correct me.If it is a small block chevy, the upgrades should work as well.
