the vacuum does drop but the weights and springs determine the mechanical advance curve as the rpms increase...I have mine set to max out at 34* at 2000 rpm and it stays at 34* all the way up to the rev limiter
pontiacgp said:this is why I like running the e-curve distributor, I set it with two dials in the distributor using a program on my pc to set the vacuum and curve and another dial to set the rev limiter... it's consistent every time
richp85elco said:pontiacgp said:this is why I like running the e-curve distributor, I set it with two dials in the distributor using a program on my pc to set the vacuum and curve and another dial to set the rev limiter... it's consistent every time
to bad I'm poorotherwise i would have one sitting on my engine as well
