Spent some more time this evening testing the system. FOUND THE ISSUE!!!!!! Removed the ECU and found the pink and white silicone tubes that plug into the firewall bulkhead loose. They looked to be originally glued into the firewall bulkhead fitting, but the glue let go and the hoses came RIGHT out. I cut about 3/4" off both tubes and re-inserted them with a little bit of blk RTV silicone on the outside of the tubes. Before RTV'n back together I vacuum tested the hose under the hood through the bulkhead and from the tube back to the controller. Everything was tight as a drum. I have litterally tested every possible compoenent on this HVAC system for a vacuum leak. I'm letting the RTV dry tonight and will vac test one more time and expect to be 100% good to go. I still have the ACDelco 9-port vac switch enroute to me so I will install it while I have the dash apart. And the 2-port vac switch tested tight as a drum again tonight.... that's the one I could not find a replacement for. So I think we're nearing the end of this fiasco. Oh, and tonight I found the temp control cable holder that snaps into the heater box broken. So I need to order a new cable tonight. This should conclude the sorting.
