Vacuum lines
Kylec345
41
8
I'm looking to remove the vacuum lines on my off of my 85 cutlass what things are powered by the vacuum lines and what can I remove that will not affect the drivability of the car?
If you are removing them make sure you remove everything.
That includes the computer, computer controlled distributor and carburetor and replace them with non computer ones.
After that you will only need vacuum lines for the brakes and vacuum advance.
Don't half *ss it.
When you remove the computer the lock up will not work unless you hook up a switch
What trans is in the car?
