the vacuum on my Malibu is only at 7" I did the blazer brake upgrade with slotted and drilled rotors and I can only tell a little bit of a difference from my stock setup. I have a vacuum canister and am thinking i need an electronic vacuum pump?
I'm running a muther thumper cam but does 7" at idle seem too low regardless of cam size?
Vacuum checked at carb under the throttle blades at a full vacuum port
