Since I have my 81 running and moving Im finding little bugs that have to be worked out. One is the lack of vacuum ports. Theres one on the manifold just under the back fuel bowl. Im using that one for the booster. I had to use a tight 90 degree fitting because it was very close to the bowl.
Ive only got 2 left and theyre both on the base of the carb. One on the right side and the other in the front under the bowl. Its a Holley 4150 750HP series.
I cant use a spacer under the Holley because of hood clearance.
I havent checked how much vacuum I have yet since I havent picked up a gauge. Thats going to happen tomorrow.
What do you guys use for the modulator ? What about the PCV ? Its like I dont have many choices.
