Having an issue with the volts light being on when the key is out of the ignition. Also when you rev the car the volts light gets brighter and brighter. It started doing this a little while before I parked it. But I figured it was just a bad alternator, so i went ahead and totally rebuilt it. Started the car up today with the new alternator, still has the same problem. Volts light is on when the key is not even in the column.
When you turn the key to the on position, the volts light goes out, but comes on again when started. Any help would be appreciated, because I am stumped... :?
