Vortec 350 build
onebadcaballero
5
I'm in the process of building a vortec 350 based from a goodwrench 350 block shortblock (10,000 miles on it).
-062 vortec heads (with drop in valve springs) milled to 60 cc's with a .015 rubberized shim head gasket. With my deck height and pistons gives a around 10.01 to 1 comp.
-Xe274 hydraulic cam
-Proffesional Products crosswind manifold
-lt headers with True dual and x pipe
-Street fire cd igniton with 8mm taylor wires
-holley 600 dp (got jets and pump cams)
-fresh th 350 with red line clutch packs, drilled valve body plate, very strong shift kit, hardened steel sprag.
How much power can I expect to make at the crank. Wheels? Also someone told me it's hard to get 300 at the wheels with a sbc & doesnt think this combo will do it.
Its going in a 1986 gmc caballero 3386 pound
who ever told you this should be beaten with a bag of nickels and publicly flogged in the town square. they probably just hate SBC's and are trying to spread their prejudice onto others.
300 hp to the wheel is not too hard on a modernized sbc.
Notice I said wheel :rofl:
who ever told you this should be beaten with a bag of nickels and publicly flogged in the town square. they probably just hate SBC's and are trying to spread their prejudice onto others.[/quote said:
I should of known his response when I pulled up to the dyno shop which was litered with hondas and acura's!
A lot of guys on here are running a similar build. I've got a 355 vortec w/ 9.8:1 and a milder cam, w/ a performer intake. I know there are a bunch of other vortec headed g's on here. You will like your combo I think, I love mine.
XE274 and a 600 carb.... just wondering why you have such a small carb for a large cam. I'd consider the 274 to be a higher-RPM cam. you put a single plane intake and a 750 carb on that and youre getting pretty close to 400 HP ...
I did some stuff. I put your specs (as far as I could tell) into desktop dyno.
Desktop Dyno roughly estimates this for your curve
Here/s a comparison of your cam vs a xe268h-10. Noptice the 268 actually makes more power and torque all the way up to 5000 RPM.
I was actually looking for a holley 750 with vacuum secondaries since I already have secondary springs and jets. I already have an xe 268 (not in the current engine-came from a previous build) but thought I would get detonation with the smaller cam. Any ideas on a reasonably priced single plane for vortec heads? Being that the crosswind professional products is a clone of the rpm air gap I figured it would be ideal for the combo but I don't have experience with these heads. Thanks very much for posting some numbers.
I wouldn't really trust a computer dyno software for anything. I used engine analyzer pro the newest version and this is what I got. I too have a xe274 I stepped up from a xe268. Here's the xe268 graph.
and heres the 274
too programs say two different things. My view.. Don't trust them.
SS camino, I used a dual plane w/ a 550 carb, like the OP mentioned. how are you getting 405 HP out of a 350 iron vortec w/ an xe268? are you using the same stuff as the OP had in his build? but either way, the programs are never right, and I agree about not trusting the programs. A program doesn't see manufacturing tolerances or other imperfections, or any kind of build error. they are good for seeing trends, though.
