Wagon exhaust
pirellinyh
n00b
May 28, 2008
I, sadly, just had to pull the entire exhaust system out of my wagon. Does anybody know of a good company that makes wagon exhausts. I need a dual exhaust system and also any suggestions for headers would be nice as well. Edelbrock 350 sbc is the engine.
pirellinyh
n00b
May 28, 2008
Nothing there that will fit a wagon. Asked if we could piece one together but it doesn't look too promising. Any more ideas, anybody?
shotgun
1,067
81
48
Nort o Philly
Do you "need" true duals?
What horsepower are you pushing?
My wagon has a 350 based off the Edelbrock performer package,camshaft, manifold and TES headers.
It merges to a widemouth Monte SS cat. convertor then splits again to daul 3" pipes, mufflers and tails.
You will need to tweak it around the gas tank.
All was installed by the previous owner. I am still in contact with him if you need more details.
joe_padavano
1,151
13
Northern VA
BSMExhaust said:
If the wagons wheel base is the same as the El Camino, the Pypes SGG20 may work. http://www.pypesexhaust.com/sys-elcamino.html
ElCos have a 119" wheelbase. All other G-body cars (2dr, 4dr, and wagons) have a 108" wheelbase. On the other hand, since the wagons and 2drs have the same wheelbase, everything except the tail pipes fits just fine. If your concern is that you want the tailpipes to exit the sides behind the wheels instead of straight back, just get some mandrel bends and cut and weld to fit.
blown78
9
i used an exhaust kit from jegs http://www.jegs.com/i/JEGS/555/30556/10002/-1 and made it fit with a little extra pipe and cutting. I do not have any pics but i will tell you what i did. I started at the back. I cut the pipes after they go over the rear end. Sot instead of running down the rear frame rails and exiting at the bumper it dumps after the rear wheels. I ran the exhaust to the crossmember witch i baught from jegs. and added a couple of inches of exhaust pipe. I used cherry bomb extream mufflers. there very small so if you use normal mufflers you may not have to use extra pipe. i also use the headers that they suggest and the whole kit worked great for me
