Ok I think I'm sold on the 8.5. I done some research and seems they hold up well if well built. I'm gonna keep an eye out for one at swaps and junk yards. are there any ways to identify a 8.5 over the 7.5 easily?
I'm not sure but the look very similar. I would say they work the same.wolfs1959 said:Is there any reasonable difference between the lakewood bars and the SSM bars?
Joe
I have a 8.5" In my Monte SS with a 450 hp motor, the rearend help up great made more then 25 passes on it with no problems at all, It is now being rebuilt at my local diff shop and the guy said they are just as good as a 12bolt and 9" if you build them up. He is gaurantee mine for 650hp. One easy way to tell a 7.5" from a 8.5" is looking at the diff cover and located on the left and right side of the housing there are little tabs, 8.5" have a square tab, 7.5" have a pointed tab. hope that helpswolfs1959 said:Ok I think I'm sold on the 8.5. I done some research and seems they hold up well if well built. I'm gonna keep an eye out for one at swaps and junk yards. are there any ways to identify a 8.5 over the 7.5 easily?
Joewolfs1959 said:Hello what would it take motor,frame and suspension wise to run these kind of times in a gbody. I used to "tinker" with them back in highschool but its been awile.
will the factory frame rear suspension hold up to the torque (launch's) for these kind of times?
could someone point me in the right direction to get the suspension set up?
rearend? swap out for 12 bolt? upgrades?... ?
I am still looking for a car at the moment but would like to get an idea of what im getting into. I'm seriously looking into a v6 car that is for sale localy that is in great shape body and frame wise(seems like alot of them i have looked at have had bad rust on the frame by the rear bumper. also what would, if any, downfalls be to starting with a v6 car, frame rearend...?
this car will be my daily driver in the summer months with some "track" time and garaged in the winter. I am looking for rock solid reliable. if i have to I will overbuild just to make sure. I honestly am getting tired of wrenching I have been doing it full time job for almost 15yrs and i want to build a gbody and drive it for the next 10 or so years without having to do any major work other than routine maint.
alot of ?'s i know
thanks
Joe
They are the same. South Side Machine was bought out by Lakewood and the same patterns are used for their bars. They work great toowolfs1959 said:Is there any reasonable difference between the lakewood bars and the SSM bars?
Joe
deanz406 said:Hi Joe-well-that's a lot to ask for.There are several things you should take into consideration.If you need a street driver-you will have to consider a PUMP GAS motor.It is going to be difficult to move a 3100Lb car-1320 ft-in the mid 11 sec range,without the compression needed to make HP.I would suggest a big inch smallblock-like a 406,try to stay around 10.0-11.0 compression.If you are closer to 11.0/1, you will have to do a mix of race gas&93 pump gas.The magic in these motors will be the cam selection, and cylinder heads you use.A pretty big Hyd cam(streetable),would be something like the Comp Cams Magnum-500/500--244o/244o,maybe a Dart 200-64cc-with a flat top piston.Actually there are several good heads for this use-the Dart--World Products SportsmanII-Edelbrock Performer RPM-Brodix Race Rite.
I can give you an example of my combo-I have an 87 Buick Regal--Pump gas 406 S/B--Comp Cam 30/30 solid-504/498-247o/254o--Speed Pro Hyp piston-shallow dish-comp ratio came out at 10.25/1,with a set of World Products SportsmanII heads at 69cc.I did do a full competition port job on the heads, and use an Edelbrock Victor intake.The rearend is a GN-8.5 w/ 4:10 gears.I had a 350 Turbo built,w/a 4500 stall Transmission Specialties converter.The car weighs 3450 w/ me in it.Best pass was a 11.84@116,with a 28" slick.I do run a little race gas in it at the track.
Another way is to build a stout 355- and put some Nitrous to it--BUTTT- you better build a strong bottom end-like Steel Crank-good rods-Forged pistons,and good heads.Well- these are some of my passing thoughts-There are so many things that u can do-EVERYTHING IS RELEVANT TO TIME & MONEY!!! GOOD LUCK-- Dean
i'm not sure if you mean that you need to eliminate the c-clips on the ford 9 or this will eliminate the GM rear with c-clips. i'm 99% sure the ford 9 doesn't have c-clips if that's what you were thinking. if not i guess i need to learn how to read 😳I found a 9" rear 4.10 soon to have cclip elim..
