May be way off base here,but James,sounds as if you are trying to engineer something without the proper knowlege and expertice. Not that I have any/enough either, but you need to be sure not to go over your head and end up with something that may run, but that you not happy with. Again,I may be way off here,but it sounds like you need to put alot more though into just what you want you car to do and alot more research on how to get it there. Your idea is great and very doable and has fantastic potential. If the execution is done correctly! So many things to consider like air flow(in and out),RPM,fuel pressure and flow. Reputable companies spend lots on research to find good combos that work well.Please find and use them. Just my two cents....not worth much but there they are!
