Thinking about adding this to my 350 and not sure if the lines can be shortened. I have the Super Vic intake with the rear cooling ports on it. Want to run hose to the ports, I believe this kit is setup to run to the temp sensor ports in the heads. And what I mean by shortened.....is can the fittings be reused? Not really familer with A&N fittings or hose, I have only used air brake hoses and fittings at work on big rigs. Thanks for any advice or help. http://www.jegs.com/i/JEGS+Performance+ ... 0/10002/-1
