Water bypass hoses question?
You can see on my big block I am now using one of the intake holes for my temp sender and the other for a water pump bypass.
ZZ4CutlaSS said:
Had to wipe the drool off my chin....looks awesome! Mind if I copy your plumbing?
That reminds about someone last week at a car show asked me if I was a plumber, I laughed and said only on the weekends.
Here are some better views, I plumbed my entire car with stainless braided hose.
😀 That's awesome! Very nice work, hope to get mine to look that good! I still need to dial in my 770cfm Holley carb and take it to the local track for a test and tune.
The water neck spacers are usually about an inch tall so you would need your bolts to be about an inch longer than they currently are, I use allen bolts and have two different lengths on my water neck and I had to cut down the long one since no makes the exact length I needed.
Cool appreciate the info....I used ARP 12 point point stainless bolts. They are expensive but I will never have to worry about them snapping off or rusting.
