Inside of my car gets wet every time i wash it or when it rains on the passenger side under the glove box and it completely soaks up my carpet ,i don't know what is the problem Any Ideas ???
sometimes the ac drain gets clogged and that will back up water causing leak, if you can lay under car & find the drain use a piece of wire or better yet air hose and check drain. be prepared for water and debris might come on to you. some of the time that,s the cure as well as what other suggestions. good luck ron
As originally assembled, the lower windshield molding had black plastic attached to help cover the seam on the cowl. Over time, the plastic crumbles away and the sealer hardens and allows water penetration into the cabin.
I have no a/c installed should that matter?
