OK what water pump pulley should i use with summit p/n [ bra-1776 ] the stock 3 groove pulley will hit the water pump before its even seated on the water pump output shaft.......i have had to shave down a fan spacer and grind it down to about 1 1/2 and put it in between the shaft and pulley i need to know what i need ....when motor is running the thing is wobbling pretty bad and eventually through a belt....what to y'all use ....and the pump i have the link to not sure if that's a short or long neck water pump.....
__________________
__________________
