It depends on how long it will set before you start it. I have used Lubriplate for years, learned it from my dad and grandpa, but, if you let the motor set a LONG time it kind of dries up, gets to a harder paste form. If it will be a while, like six months or more, wait to do the cam lube and just use good motor oil on the cylinder walls, rings, and bearing surfaces.
I have had the best luck swapping out oil filters right after the cam break in cycle, and then oil and filter at 500 miles. A good filter can get clogged at cam break in with all the particles and such from break in process and foreign objects from general assembly. I am a Valvoline guy, VR1 Racing Formula for the ZDDP. Pretty much swear by Wix filters too.
