Recall numbers are Y26 and Y36. There's a go/no-go gauge to check if the studs are stretched. Dealership replaces as necessary and uses an updated torque spec.
Shame on Dodge, Ram, Fiat or whomever makes this stuff if they manufacture a wheel stud/lug not combination that doesn't snap or strip the lug nut threads when over torqued at time of torquing.Recall numbers are Y26 and Y36. There's a go/no-go gauge to check if the studs are stretched. Dealership replaces as necessary and uses an updated torque spec.
I will pass this info on to boss thank youRecall numbers are Y26 and Y36. There's a go/no-go gauge to check if the studs are stretched. Dealership replaces as necessary and uses an updated torque spec.
The truck is now repaired I’m not sure if he saved old parts for evidence or notShame on Dodge, Ram, Fiat or whomever makes this stuff if they manufacture a wheel stud/lug not combination that doesn't snap or strip the lug nut threads when over torqued at time of torquing.
Broken wheel studs in my world are from being loose.
To determine if it's the issue that Driven is indicating in those service bulletins or what I usually see, the evidence is not shown in this photo. Need to see both sides of the wheel, the pilot engagement surface and the hub/studs.
