What driveshaft can I use?!
spidereyes455
788
1,645
Northeastern PA
There were only 3 different drive shafts used on g bodys . El caminos are different from anything else and the only difference between the other 2 was wether the car had a 7.5 or an 8.5 rear. Shafts for cars with an 8.5 (only used in H/O 442 and GN / T types) are 1 inch shorter. If you still have the shaft for your malibu it will work as a 200-4r is the same length as a TH350, Th 200 TH 250 ect.
