i had my buddy at the parts store swap out my dist for a new one. i put my peformance hei ignition module and capacitor in it and put on a msd cap and hei coil. now i just need to know what the base timing is on a sbc350 for when i drop it in. and also what is a good timing set that you guys are running. it is a vacuum advance distributor. i only have exp with locked dist so how should i set the timing on this one. do i set it at idle with the vacuum line connected or disconnected or do i have to set it at a certain rpm range?
