hey guys,
I am going to do something that not many people have ever done; converting my dual electric fan setup back to the stock mechenical fan with clutch. I lately lost trust in the electric setup since i replaced a thermo switch twice and a relay once. i also believe that the original fan has the best cooling capacity.
I still have my original fan shroud for my '79 Regal but I threw away the fan and clutch. I measured the shroud hole diameter and it turned out to be 21" (only measured horizontally). after that i searched on summit for an aftermarket clutch fan. but 19" is the biggest diameter i found. (a flex-a-lite)
Now I am not sure which diameter to go with since I thought that those 19" fans are for trucks. does anybody know what is the appropriate diameter?
thanks alot.
thanks alot.
