ok with my engine below and these cam specs round about what should i have my timing set at. i have it at 12deg now demon says 14 to 16 for my carb im lost. here is my cam specs
Brand: Edelbrock
Product Line: Edelbrock Performer RPM Cam and Lifter Kits
Part Type: Camshaft and Lifter Kits
Part Number: EDL-7102
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,500-6,500
Intake Duration at 050 inch Lift: 234
Exhaust Duration at 050 inch Lift: 244
Duration at 050 inch Lift: 234 int./244 exh.
Advertised Intake Duration: 308
Advertised Exhaust Duration: 318
Advertised Duration: 308 int./318 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Valve Springs Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Timing Chain and Gears Included: No
Assembly Lubricant Included: Yes
Pushrods Included: No
Rocker Arms Included: No
Gaskets Included: No
Quantity: Sold as a kit.
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 308/318, Lift .488/.510, Chevy, Small Block, Kit
Brand: Edelbrock
Locks Included: No
