Wheel and Tires looking for info and suggestions
Turbo Zach
2,534
5,874
Looks like you have a Monte? If so I would find a used set of N90 wheels for that car if you are trying to be cheap.
Thanks guys.
Do you know of anyone who had tried late 80's trans am rims on g body cars? There is a set for sale locally here, and I am trying to visualize what they would look like. Here is what I'm talking about:
There's a thing about those rims- there are fronts and rears (different BS/offset or something), and they need spacers. You can use the same size spacers if you get 4 fronts or rears, but I forget which.
I always liked that wheel. I have to agree that it's definitely a Pontiac thing, though.
9,619
12,709
I am thinking either Riddler 675 or Torque Thrust II. Anyone e have experience with Riddler?
I would say you can't go wrong with either rim and since you would be buying new you can buy the correct width and offset to fit your car instead of trying to adapt used rims to fit your car.
Jim Rockford
308
523
Shelby,N.C.
BobinHSV
29
37
Here is my '87 El Camino with staggered 17x7 225 45ZR17 front, 18X8 245 40ZR18 on rear.
Ribbedroof
4,923
7,059
Wellston, OK
Something to consider on OE later model (non G body) wheels is that the center bore needs to be opened up to fit over the bearing hub. It's not a LOT, but it is different. The S10 wheels on my avatar car are an example of such.
BobinHSV
29
37
1 1/2". Full BMR Front and Rear suspension including 1 1/2 lowering springs. Unbelievable change in driving performance. This car also has Blazer front spindles with separate hub assy and rear discs.
Gwarren79
711
1,549
Safford, AZ
if you can find them, look for 15 and 16 inch (16 front) wheels from a Trans Am. Run the 15 on the front 235/60r15 and 255/50r16 in the rear
You can buy four fronts brand new from the usual scumbags for a song. I wouldn't waste time or money on hunting for a set of four used fronts.
