My 84 Monte has a rearend out of an 86 Grand National.Can I go 4.5 on the back spacing with a 15 x 8 wheel and 26" tall tire?
JRG53 said:I've seen this question about 1000x since I've been a member of this site. Blake442 says not to go more than 4 inch on back spacing. Anything else will rub.
Thanks good advice. :lol:pontiacgp said:I had 16x8 with a 4.5 backspacing and 245-50-16 tires all way around and no rubbing except the front would rub the F body sway bar on a tight turn. The back did look a little funny cause the wheels looked tucked in and a narrower track than the front but I cured that with a 67 Chevelle rear end
and I'd be happy to try out those coys for you just to make sure they fit..
