On my way home I noticed a roar from my Left Front wheel. When I got home I took the rotor off to inspect the wheel bearings and found that the outer bearing had came apart and the race has worn a groove in the rotor causing the race to wobble around. So, I need a replacement rotor. I work at a salvage yard so I have access to a bunch of S-10 Pickups and Blazers. Will the 99-04 2WD S-10's and Blazer rotors work on our spindles? Are they the same size? Should I see if any other yards on our delivery route have a rotor from a G-Body they could send back with our driver? (We don't keep older cars on the yard, except for 1 stray '66 Impala. Will that rotor work?) Should I buy a new rotor? If so what brand would you recommend? I haven't had very good luck with new, aftermarket rotors lately so I was leaning towards the used route but if someone here knows of a good brand that they have experience with, I'm open to suggestions.
Thanks for reading.
Thanks for reading.
