I have camaro 15 X 7's on my wagon with 255/60 in the back with plenty of room for wider and 235/60 in the front and they dont rub but that might change when I drop it
jrm81bu said:adumb said:jrm81bu said:If they are coming off a 4wd blazer they might have too much backspacing. They might fit and not rub but they won't look right. they will look tucked in.
sh*t
that's kinda what i was afraid off. any good steelies i could use?? I was gonna maybe talk to junkyard down from $35. maybs i'll go with soft8's in the rear and the 14x6 in the front.
i need a relatively cheap way of geting new tires on this, but im also looking to the future. i don't wanna change my tire setup half way through summer. this way if i upgrade, it'll only be getting another set of soft8's up front.
Sounds kinda like you already have the answer :lol:
all4gss said:I'm looking to order some 17x8" wheels to replace the 14's on my 1980 elky. I've seen conflicting stories on what back spacing I need. Do I need 4" or 4.5" backspacing?
Also. What tire size would work best all the way around?
235/50/17
245/45/17
Thanks for your help.
all4gss said:Thanks for the feedback jrm81bu. Could you post a front and rear pic low enough so I could see how the 4.5" bs sticks out?
Have you had any rubbing with the 235/50/17?
