79loserbluebu said:Rule of thumb in drag racing is .1 second for every 100lbs lost. You figure the hood doesn't even weigh half of that though. I don't think using a holesaw is going to do much for you
It seems to me the amount of holes you would have to cut out of the sheet metal to add up to enough weight to even make a bit of difference would be substantial besides every hole would have to be sealed where you cut through to prevent rust.
I would probably go with as many fiberglass,aluminum and lexan parts as possible to lighten it up.
Of coarse my solution to the extra weight is to just add more power.
