for years ive wanted an ignition box, its suppose to give a hotter spark, everyone uses them (or it seems that way)
but who really uses them? what kind and what is the application for its use?
im wondering because MSD has a new box out, street fire. it doesnt have the output of the old MSD 6A and its relatives in the 6 series but is easily under 150 bucks and installs the same way.
now i always thought it was weird that the buick V6 had a spark plug gap of .060 but chevy's usually had a gap of .030. i figure since the gap was so big the ignition could use the help from a box.
ideally i'd like the digital 6 plus by MSD, the volts going to the coil is higher than the 6A/AL. the millijoules going to the plugs is higher than the 6A/AL and seems to use less amps per 1K RPM. second choice would be 6A because i dont need a rev limiter because the engine hardly sees 4K as it is and that is below the cars rev limiter from the factory. but both are kind of on the expensive side, especially the digital 6 plus.
i'm really looking for people that have used these things in stock or near stock applications, especially if it was used with a buick V6 non turbo. one thing im almost obsessive compulsive about is the ignition and making sure those plugs are getting as much spark as possible.
