V6UnderPressure said:
...Is the vortec a decent motor for hp? I'm trying to get 450-500 naturally aspirated if possible out of a 383 stroker...
The vortec L31 is the best FACTORY long block to start with. Naturally aspirated you can hit 450 HP with the stock block and heads. The blocks are an excellent casting and the cranks are pretty good too. You'll need to check the rods, you want the PM (powdered metal) rods which some Vortec engines got from the factory, some LT1 engines got them too. You'll have do some mods to the heads, cut the valve guides down so that you can run a high lift cam, the beehive springs, and then do your porting and polishing. To hit 500HP NA in a Chevy you'll need new crank and rods, and aftermarket heads too.
...But anyhow, I've done quite a bit of research on this, and if you can build an olds for close to the same price, you've either cut corners or gotten free parts...
Nope. Olds engines can use the factory parts to 500 HP that you would have to replace to run a Chevy. If I get some light machine work done to the block, it will be no more than a good Vortec Chevy core will cost, and probably less actually. I won't have to buy a new rotating assembly, but the Vortec guy will. At the most, I might lose a rod that doesn't qualify after I measure it out, and I can buy used good rods, reconditioned, instead of more expensive aftermarket stuff. The piston prices are not too different. I can run stock "C" code big block heads on my Olds 350 that will outflow any set of Vortec small block heads. Then I just need a Performer RPM intake so that I can match the massive ports in the head to the intake properly. If I want to spend the extra money I saved by not buying a crankshaft, I can put that money towards Edelbrock aluminum big block heads.
...By the way, does anyone make a supercharger for an olds 350? Been having no luck finding one. Since I would like to supercharge it in the future, it's just another reason to go Chevy.
If you contact the ProCharger guys, they can get you set up. I have seen the Buick 350 and big block setups on cars, and I am sure that they make them for Olds as well. Even if they didn't, it's just a custom plate bracket away from mounting it up.
So really it just comes down to how much effort you are willing to put in yourself, versus how much you have to pay someone else to do it for you. Its all just a matter of choice.
