OK pimpdude, I'm gonna try !! #1-Take the cap off the master cyl. #2- fill it up. #3- loosen or take off the FRONT brake line from the master cyl(rears are still blocked I hope)#4- have someone SLOWLY push the brake pedal to the floor, when it gets to the floor, put your thumb over the hole and have them release the brake pedal.#5-Slowly take your thumb off the hole and watch to see if fluid starts to come out of the hole. If so, hook the brake line back up and tighten it.#6- Go to the RIGHT front and loosen the bleeder on the caliper(do NOT push on the brake pedal),as you watch, in a little while fluid will start to run out along with air bubbles. Let it run until only fluid comes out(check the fluid in the master,fill if needed)and tighten the bleeder. #7-Go to the LEFT front and repeat the process, including making sure the master cyl. is full. You have just Gravity Bled your brakes ! #8- Set the cap back on the master cyl, don't tighten it, just set it there, and pump the brake pedal slowly several times. It will take a few pumps, because you have to fill the calipers with fluid. Once you get a pedal of some kind, take the cap back off the master, and bleed the RIGHT front again(gravity)check the fluid in the master, and repeat the process on the LEFT front. You should now have a decent pedal, so you can now HOOK UP THE REAR BRAKES !!! :lol: ................................mickey-d 8)
