Hey guys, just thought I would see if someone can help me out. I have been having a lot of trouble getting my new motor to finally start up. When I was finally ready to start it I could not seem to get any power to the starter. I checked all connections and was receiving good voltage to all areas. The previous owner had a battery relocation kit in the trunk so I checked the ground connection at the frame and cleaned it up and sealed it but it did not make a difference. Then I checked the instructions and it said to run 10 feet or more of positive wire you would need 00 gauge wire (very thick) and he only had about 14 feet of 4 gauge. So today I put the battery Back under the hood and ran a much shorter 2 gauge wire for the positive and the negative. It did not make any difference at all. Still get all power to the lights and good voltage but it won't engage the starter at all. When I remove the ground from the frame and ground it to the on the starter it engages and works great. I've tried cleaning up 4 difference spot on the frame and rad support but it does not make any difference. I don't have a long enough negative cable to run to the motor but the block is grounded to the frame already anyways.
What I am doing wrong here? It's getting very frustrating trying to get this worked out, so any insight on what I need to do would be more than greatly appreciated.
Dave
