I have a 75 Trans Am front clip. Will the steering box work on my 83 wagon and what issues will I have. IE hoses, stops? Can anybody tell me the spec on this box? Which pitman arm should be used?
Thanks
Thanks
Anyone?flatheadfever said:I have a 75 Trans Am front clip. Will the steering box work on my 83 wagon and what issues will I have. IE hoses, stops? Can anybody tell me the spec on this box? Which pitman arm should be used?
Thanks
G-Body_Vet said:Something else that comes to mind is that there was a change in the pressure hose fittings IIRC. I believe the change over was going from flared fittings, to an o-ring set up when everything started going metric. I'm pretty sure it's just a matter of swapping the fittings from one box & pump over to the other. It's been years since I've done it, but I'm pretty sure that's what it is. Probably doesn't help with your question, but just one more surprise you'll expect if the box fits.
