Wondering if any of you guys have ever came across an issue like this before. I had a windshield installed last fall. The technician never installed the steel trim along the bottom of the glass because I had no idea where the hardware was. I went to put the trim back on yesterday and I cant get it to sit flush with the glass like it should. Now the problem is that the connector off the windshield for the antenna is hitting the trim causing it to stick out. I thought maybe its not on all the way, but I cleaned off the connector on the car and used some dielectric grease to make sure it was on all the way. I also thought maybe the connector had more volume to it compared to the OEM if that makes sense. But of course the company claims their glass supplier provides EXACTLY the same as the OEM glass. The trim is the factory piece not aftermarket and the technician had never heard of such a thing over 23 years of installing glass on older cars.
Anyone have any ideas???
