Winter steel wheels for Cutlass
Kevin...I show Buck's Auto Parts in Edmonton having a couple of Gbody cars...the numbers are the date in yard...so not sure they'd still be there or not. Might be worth a check.
1981 OLDSMOBILE CUTLASS WHITE COUPE 7/31/2016
1985 OLDSMOBILE CUTLASS BLUE COUPE 9/15/2016
53322, 231 Range Road
Edmonton, Alberta
Phone: (780) 464-6922
I phoned them and they said the wheels and tires were long gone.
Not sure but you could have them measure....
The easiest way to measure backspacing is to lay the wheel face down, then lay a board or something flat across the back of the rim. Then measure down to the mounting flange, this will give you your backspacing number.
It the same BS as the Gbody. Those look like they are off a 2wd Sonoma and referred to as the sawtooth wheels. 2wd Sonoma / S10 wheels are a direct fit for Gbody cars. The 4wd wheels bolt pattern will fit but have too much positive offset and may rub the wheelwells / fender lip. If you can find ZQ8 Sonoma wheels they bump you up to a 16" tire on a factory GM rim with the correct backspacing.
The studs are pretty aggressive but with 100 lbs of sand in the trunk ( to take some weight off the nose ) they will definitely be an improvement over any all seasons you may find.
Well, I made a couple of phone calls and there is only one rim from an s10 in the whole area. I am SOL for wheels.
I phoned Canadian Tire and they want over a hundred bucks per wheel for stamped steel wheels.
Are you still looking? I have a full set of 14" rims that have roller tires on them. You can have them!!! I'm in pa and if you wanna drive here, come and get them. Free dollars and no cents.
