couple parts to install
I have a autometer tachometer that i need a little advice on the size wire needed to may the installation. the direction didn't say what size wire to use but it did say use a 3amp fuse, I'm assuming it gets wired to the fuse box, so I guest that about 41/2 ft. and will I need a filter to keep the need from bouncing around, it does have a Hei distributor if that matters .
2) which color wire on the light switch will I tap into for the lights on the tach.
3) looking to switch to a electric oil pressure gauge, the fitting on my copper line is a little wet with oil , don't want to chance trashing my new carpet and interior. if someone know a good brand electric gauge that come with the oil pressure switch and wiring to purchase I would appreciate .
thanks
thanks
