Ya, kind of losing me, Rabbit.
Starter Relay(?): ground the bracket, battery to one side, starter to the other, purple to the 's' small terminal, leave one empty. If you're using a relay, jumper the two studs on the starter together. Also, the starter can no longer be used as a battery distribution point with the relay.
Coil & RTR Dist. : tap into 12 ga. pink, attach to coil + (verify pink stays hot through crank/start).
Don't leave that coil of wire on top of the coil. Get the wires off the header.
