I had the genious idea to repair the wiring harness of my car and bring it back to OEM since it was crappy made by the workshop when they swapped the engine in...
I bought a Powermaster 150amp alternator (67293 ) with internal voltage regulator, and I wish to get the best possible wiring while restoring the OEM cable-situation. The big heavy wire will be going from the alternator to the battery-positive, that's obvious, even to me.
What's baking my brain is the question on how to correctly connect the 2 cables going to the fusebox? I understand that 1 is for keyed contact while the other is permanent current. Is the ignition-keyed wire the one receiving the current from the internal alt-voltage regulator? There was 1 connector provided with the alternator.
![20200104_164821.jpg 20200104_164821.jpg](https://cdn-0.gbodyforum.com/data/attachments/122/122127-d247854294e27b7f503e66832220ad5d.jpg?hash=0keFQpTie3)
The next two pictures shows some of the horror made by that loonatic who swapped the V8 in instead of the V6...
![20200104_160207.jpg 20200104_160207.jpg](https://cdn-0.gbodyforum.com/data/attachments/122/122130-73978d150f727f829e5a09fe0fb14e91.jpg?hash=c5eNFQ9yf4)
On my wifes 1972 firebrid, I can't see where the cables are supposed to go, only guess, since the original wire harness wrap is still in place. Also, why is there a 30amp fuse? Is it to protect the other wire with permanent current?
![20200105_143714.jpg 20200105_143714.jpg](https://cdn-0.gbodyforum.com/data/attachments/122/122128-6c02e0b6d977a1453d1ebeb16c0b3b00.jpg?hash=bALgttl3oU)
I am totally out of ideas -.- please help!
![20200104_160151.jpg 20200104_160151.jpg](https://cdn-0.gbodyforum.com/data/attachments/122/122129-6e4d10dddd9a240f0cad611478a88c86.jpg?hash=bk0Q3d2aJA)
