I swapped a1968 Olds 350 W-31 Spec engine into a 1980 El Camino with an anemic V-6. It had a computer controlled carb, and and ECM of sorts that I was advised to snip and remove when going to '68 specs. Originally I had decided to go with the retrofit distributor too, but later was convinced that HEI would be superior in every way. The El Camino harness has the infamous pink wire to the distributor which I found and it is plugged-in. I am getting spark to the plugs, but the engine does not fire. It has air, gas and spark but makes no attempt at starting. I checked the distributor and was correct CCW firing order (Oldsmobile). I brought #1 to TDC and guestuimated 14 degrees advance (B). It should be close enough to fire as I move the distributor + or -...yet not once has it picked up backfired or shone any sign of firing. Of course I trashed the ECM unit that was mounted on the kick plate inside, under the glove box. I can't rehook it up and see if it starts, but all who advised me said I could clip it and can it which I did. Is it possioble there is some fail safe switch that is causing it to just crank and crank and crank and crank? Compression leakdown is coming soon, but this engine has never fired and has all new rings, pistons, valves, cam, pushrods and lifters. Something simple is just blocking my old school mechanic. Anyone have any ideas? I have two great mechanics just scratching their heads...and one can't afford a bald spot!
