wiring relay w/ switch HELP!
gbodyera
239
36
Miami,FL/ DET,MI
how do i wire in a switch with my fuel pump relay and for my electric fan setup? I dont want to wire them in with the ignition. I am stuck here. Can someone please help or suggest a better way? Ive read the diagram that came with both setups but they dont mention how to wire in a switch, only to igntion power.
Fuel pump negative-ground
87-fuel pump positive wire
86-on/off switch?
85-ground
30-battery w/ circuit breaker in between
What kind of switch should I use? I have 2 types. 1 with 2 terminals on the back and 1 with 3 on the back of the switch?
Also I have a in-line fuse to wire in but dont know where to put it.
The two prong terminal will work and it's wired into the # 86 wire and for the fuse that would go in the constant feed wire # 30
