Work in progress, getting my '85 El Camino back on the road
For now they will have to stay. I maybe putting 17's on it later since I plan to upgrade the brakes anyway.
Uppers finished with poly bushing and Pro Forge balljoints:
Lowers waiting for the paint to dry:
Out comes the smog pump:
Thanks to Energy Suspension for sending me the right shells for the lower control arms, I managed to get the front end back together. Only missing two grease fittings for the lower ball joints. I packed them away safely when I had to stop two weeks ago. Must've packed them away very good, cause I forgot where I've put them :owned:
Reactions: pontiacgp
On to the rear. Ripped out the rear end today.
All bushings are completely shot, as are the shocks.
I might as well upgrade to a true trac 3.42 while the rear end is on the bench.
The spring perches were booger welded by the previous owner, so there's some welding to do as well.
You Sir have an eye for the essential things in life.
Reactions: fleming442
I have a devoted relationship with the fine beers of Germany, more so witht those of Barvaria. I may not drink anymore but when I do again it will be with Deutsches bier from Deutschland. Now go, refill that rack. 😉
I installed the factory sway bar on my elco rear, along with the "cargo" springs. It had the factory air shocks so I just replaced them although I think they were still fine. This really tightened things up and I feel much safer, nothing else was done. I had a '69 Chevelle without the rear sway bar and almost lost it a couple of times, started zig-zagging uncontrollably. Same with an old 70's Pontiac, I think it was.
Haven't looked or gone back under there yet but I wonder if Delrin bushings aren't available?
The rear is getting Energy Suspension PU bushings. I'd love to put a swaybar in there, that's on the plan later on.
Yes, I did a little reading up on the various materials and found the application (location) will dictate the type of material recommended, so Delrin, PU, rubber depending, even spherical bearings for some enthusiasts.
I used the light-weight rear factory sway bar since GM never offered them on these elcos and didn't want to create unanticipated issues, it came from a cutlass g-body I believe (FWIW).
Your elco is coming along nicely, good job.
