I have rims the same specs as the GTA front rims and I run 245-50-16. The front tires did rub the sway bar at full lock but I have a Z box now so no more rubbing but my u-turns are a little wider
pontiacgp said:I don't and I'm not from Chicago so it's not hard for me to be humble... 8)
pontiacgp said:a deeper dish means less backspacing...the hub sits closer to the inside of the rim...this is from a GTA site
"The GTA’s are marked “front” and “rear”.
Front offset:
Front backspacing: 4.75”
Rear offset
Rear backspacing: 5.25”
and from another site I found I was wrong with the reason of needing clearance in the front for the different wheels...
"The wheels were unique in that the rear ones were offset 16mm due to the rear axle width; the front rims were zero offset. "
